Salta al contenuto principale
Drift HD 720 Microphone Replacement
Cosa ti serve
  1. Drift HD 720 Microphone Replacement, Battery: passo 1, immagine 1 di 2 Drift HD 720 Microphone Replacement, Battery: passo 1, immagine 2 di 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: passo 2, immagine 1 di 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: passo 3, immagine 1 di 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: passo 4, immagine 1 di 1
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: passo 5, immagine 1 di 1
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: passo 6, immagine 1 di 1
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
Conclusione
Baylor, Team 10-16, Williams Fall 2015 Membro di Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 343
