Cosa ti serve
Pull out the power plug
Unscrew the two blue caps of the carbon brushes with a slotted screwdriver. Caution: they are under spring tension!
Remove the springs
Shake out the carbon brushes. If necessary, carefully pull out the round spring guides of the brushes with needle-nose pliers.
Insert carbon brushes with the springs. The alignment of the brushes must match the alignment of the axis! The brushes must be able to smoothly move along the guide.
While applying pressure to the springs, check whether the brushes are in contact with the rotor by slowly turning the shaft.
Screw the blue cover cap back on.
Unclip the hanger (already removed here)
Unscrew thumb cap (already removed here)
Remove carbon brushes (see instructions)
Remove the 4 Torx screws
Remove the housing by lifting it upwards
Loosen the Torx screws holding down the tension relief (removal is not necessary)
Lift the rotor out of the housing at the front end and pull it out of the housing together with the winding and switch in the direction of the axis towards the front.
During this process, the two plug contacts to the electronics will become detached.
Remove the rubber bumper around the rear ball bearing.
Pull the rotor forward out of the mechanism. The winding and switch do not have to be removed for this (separated in the picture).
Insert the new rotor into the winding from the front.
Slide the rubber bumper onto the rear ball bearing.
Slide the rotor along with the winding and the switch into the housing at an angle from the front at the top. Lift the electronics slightly so that the contact pins of the electronics fit into the contacts of the switch.
Make sure that the rubber bumper is correctly seated.
Make sure that the spring for the shaft lock at the front end is correctly seated.
Put housing back on
Tighten the 4 Torx screws
Install carbon brushes (see instructions)
Clip on hanger
Reattach thumb rest (not shown here)
Function Test
Function Test
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
