Salta al contenuto principale
Dremel 8220 Motor Replacement
Cosa ti serve
  1. Dremel 8220 Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Dremel 8220 Motor Replacement: passo 2, immagine 1 di 1
    • Remove the ring located around the speed selector switch by pulling apart on either side. (This should require very minimal force.)
  3. Dremel 8220 Motor Replacement: passo 3, immagine 1 di 1
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Dremel 8220 Motor Replacement: passo 4, immagine 1 di 1
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a spudger.
  5. Dremel 8220 Motor Replacement: passo 5, immagine 1 di 3 Dremel 8220 Motor Replacement: passo 5, immagine 2 di 3 Dremel 8220 Motor Replacement: passo 5, immagine 3 di 3
    • Remove five 10.5 mm Torx T9 screws.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Dremel 8220 Motor Replacement: passo 6, immagine 1 di 2 Dremel 8220 Motor Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove broken motor. Lift out the motor until you can see the wires that connect to it.
    • Remove the clips where the wires connect with the motor. This can be done with your fingers of a pair of tweezers.
    • You should then be able to reconnect a new motor and reassemble the device.
Conclusione
Altre 4 persone hanno completato questa guida.
3 Commenti
Have you ever taken apart the motor? If so how?
Micky Ashey - Replica
Is there polarity correctness of the motor connections?
cal yoshikawa - Replica
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
qedelectrics - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 63
Tutti i Tempi: 4,398
