Salta al contenuto principale
Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
Cosa ti serve
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, immagine 1 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, immagine 2 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, immagine 1 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, immagine 2 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: passo 2, immagine 3 di 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, immagine 1 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, immagine 2 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 3, immagine 3 di 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, immagine 1 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, immagine 2 di 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: passo 4, immagine 3 di 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
Conclusione
Altre 3 persone hanno completato questa guida.
Michael Smith
Membro da: 02/10/16
175 Reputazione
1 Guida realizzata
USF Tampa, Team 3-4, Sullivan Spring 2016 Membro di USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,107
