Salta al contenuto principale
Dremel 7300 MiniMite Cordless Collet Replacement
Cosa ti serve
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, immagine 1 di 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, immagine 2 di 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: passo 1, immagine 3 di 3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, immagine 1 di 3 Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, immagine 2 di 3 Dremel 7300 MiniMite Cordless Collet Replacement: passo 2, immagine 3 di 3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
Conclusione
Altre 7 persone hanno completato questa guida.
Kat
Membro da: 02/10/16
840 Reputazione
3 Guide realizzate
USF Tampa, Team 3-4, Sullivan Spring 2016 Membro di USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Membri
4 Guide realizzate
2 Commenti
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Replica
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 32,522
