Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If bearings are worn or if fan is damaged, the replacement of the entire bearing assembly is required. After opening the case, the bearing assembly can be lifted out by hand.
  1. Start by removing the housing cap by unscrewing it. Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Using your hands, carefully remove hanger from casing.
    • Using your hands, carefully remove hanger from casing.
    Mine seems to have solid caps without the slot. How are this type removed?
    claire roche - Replica
  3. Remove the brush caps (one on each side) by using a flathead screwdriver bit. The brush caps are spring loaded.
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Use a plastic opening tool to gently wedge apart the hard plastic threads.
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Use your hands to carefully remove the back casing so that none of the components fall out.
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside. To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Using your fingers, carefully pull the circuit board from the casing.  This will make it easier to remove the power cord.
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
    Hello I need to know or see where is plugged the blue wire, I think that know the problem it is disconnected? Thank you. if you need my e mail. charbonneau_eric66@hotmail.com
    charbonneau_eric66 - Replica
  10. Carefully remove both wires from circuit board with your hands.
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
  11. Carefully pull up on the shaft to lift out of the casing. Carefully pull up on the shaft to lift out of the casing.
    • Carefully pull up on the shaft to lift out of the casing.
    The blue wire has a seat below the brushing casing of the Dremel bottom assembly (you can see a little notch). Thus place the blue wire before putting back the stator…
    LLange - Replica
  12. Firmly hold the field assembly in one hand and the bearing assembly in the other. Carefully slide the bearing assemble out of the field assembly.
    • Firmly hold the field assembly in one hand and the bearing assembly in the other.
    • Carefully slide the bearing assemble out of the field assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
Eugene
Membro da: 20/01/2016
269 Reputazione
1 Guida realizzata
USF Tampa, Team 15-4, Remmell Spring 2016 Membro di USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Membri
10 Guide realizzate
Nice guide. FYI, I've found that removing the rotor/bearing assembly is just as easy without removing the input power wires.
Chris Barth - Replica
Absolutely, it is.
josephbolton -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 170
Tutti i Tempi: 8,485
