Salta al contenuto principale
Dragon Touch Y88X Plus Camera Replacement
  1. Dragon Touch Y88X Plus Camera Replacement, Camera: passo 1, immagine 1 di 2 Dragon Touch Y88X Plus Camera Replacement, Camera: passo 1, immagine 2 di 2
    • First, start by removing the backplate from the device using your IFixit opening tool.
  2. Dragon Touch Y88X Plus Camera Replacement: passo 2, immagine 1 di 1
    • Next, remove any adhesives that are keeping internal components of the device in place.
  3. Dragon Touch Y88X Plus Camera Replacement: passo 3, immagine 1 di 1
    • Carefully peel the old battery from the adhesive using your iFixit pry tool.
  4. Dragon Touch Y88X Plus Camera Replacement: passo 4, immagine 1 di 2 Dragon Touch Y88X Plus Camera Replacement: passo 4, immagine 2 di 2
    • In order to remove the old camera, you must disconnect the ribbon that connects to the camera.
    • To remove the ribbon, flip the black switch where it is connected to the motherboard and gently pull the ribbon out and replace it with your replacement Dragon Touch Y88X Plus camera.
Conclusione
Craig B
Membro da: 10/30/23
247 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 44
