Salta al contenuto principale
Dragon Touch MID 7138 Motherboard Replacement
Cosa ti serve
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: passo 2, immagine 1 di 1
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: passo 3, immagine 3 di 3
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: passo 5, immagine 1 di 1
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: passo 7, immagine 1 di 2 Dragon Touch MID 7138 Motherboard Replacement: passo 7, immagine 2 di 2
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
Conclusione
Trevor Farkas
Membro da: 01/26/17
101 Reputazione
1 Guida realizzata
IUPUI, Team 2-4, Baechle Spring 2017 Membro di IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 597
