Introduzione
This guide will walk you through how to replace the battery of the device. In order to do this you must first remove the back cover. Once the back cover is off, you can remove and replace the battery.
Cosa ti serve
Insert the plastic opening tool between the white back cover and black front over.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
Quasi finito!
Conclusione
