Salta al contenuto principale
Dopo Double Power 7 Speaker Replacement
Cosa ti serve
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: passo 1, immagine 1 di 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: passo 3, immagine 1 di 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: passo 4, immagine 1 di 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
Conclusione
mike pelosi
Membro da: 10/30/15
682 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 1-2, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 170
