Salta al contenuto principale
Dopo Double Power 7 Motherboard Replacement
Cosa ti serve
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: passo 1, immagine 1 di 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: passo 2, immagine 1 di 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: passo 3, immagine 1 di 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: passo 4, immagine 1 di 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: passo 6, immagine 1 di 2 Dopo Double Power 7 Motherboard Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: passo 7, immagine 1 di 1
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: passo 8, immagine 1 di 2 Dopo Double Power 7 Motherboard Replacement: passo 8, immagine 2 di 2
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
Conclusione
mike pelosi
Membro da: 10/30/15
682 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 1-2, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 487
