Salta al contenuto principale
Doov v15 Battery Replacement
Cosa ti serve
  1. Doov v15 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Battery Replacement: passo 2, immagine 1 di 3 Doov v15 Battery Replacement: passo 2, immagine 2 di 3 Doov v15 Battery Replacement: passo 2, immagine 3 di 3
    • Use an ifixit opening tool to slide around the phones back cover, loosening it and allowing for an easy removal. It should easily separate from the chassis. Make sure to trace it around the entire phone.
  3. Doov v15 Battery Replacement: passo 3, immagine 1 di 1
    • Once the back casing is removed, the battery will be visible. Prepare your replacement battery (BL-C-17) and use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  4. Doov v15 Battery Replacement: passo 4, immagine 1 di 2 Doov v15 Battery Replacement: passo 4, immagine 2 di 2
    • Install the replacement battery by sliding it downward into the empty slot. Make sure the front of the battery faces you.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 146
