Salta al contenuto principale
Dolce Gusto Oblo gasket of the water tank connector assembly replacement
Cosa ti serve
  1. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove water tank, pod holder and drip tray: passo 1, immagine 1 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove water tank, pod holder and drip tray: passo 1, immagine 2 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove water tank, pod holder and drip tray: passo 1, immagine 3 di 3
    • Let’s begin by removing the water tank.
    • Then lift the gray handle then remove the pod holder.
    • Let the gray handle lifted as you will need this in order to remove the top plate.
    • Then remove the drip tray.
  2. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove back plate screws: passo 2, immagine 1 di 1
    • Rotate the coffee machine so the back plate is facing you.
    • And remove the 8 screws using a Torx TR10 screwdriver.
    • 6 Torx TR10 15 mm screws
    • 2 Torx TR10 8 mm screws
  3. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Free the top plate: passo 3, immagine 1 di 2 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Free the top plate: passo 3, immagine 2 di 2
    • Once the back plate screws are removed, look at the top plate of the coffee machine.
    • Then detach the top plate using an opening pick or a plastic opening tool if needed.
    • The top plate if firmly maintained by clips all around its perimeter, it may require a little force to detach it.
    • Once it’s detached fully, do not remove the top plate fully for now as the power button behind the top plate is connected by wires to the rest of the coffee machine and need to be removed to free the top plate fully.
  4. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the top plate: passo 4, immagine 1 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the top plate: passo 4, immagine 2 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the top plate: passo 4, immagine 3 di 3
    • Lift carefully the top plate and turn it so you can see the back of the top plate.
    • Locate the power button behind the top plate.
    • Then remove the 3 screws securing the power button using a Philips #1 head screwdriver.
    • 3 Philips #1 8 mm screws
    • Warning: the button has two parts that are not attached together, the top of the power button may fall, careful to not lost it (see 3rd picture).
  5. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the front plate: passo 5, immagine 1 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the front plate: passo 5, immagine 2 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the front plate: passo 5, immagine 3 di 3
    • Locate the 2 screws securing the back plate and the front plate together. Then remove the 2 screws using a Torx TR10 screwdriver.
    • 2 Torx TR10 15mm screws
    • Once screws are removed, pry on the plastic rings on the right side of the front plate using a plastic opening tool to detach it partially (see 2nd and 3rd picture that shows how to detach the right side)
    • Then do the same on the left side.
    • Pry gently, caution not to break the plastic.
    • Then lift the front plate to detach the bottom of the front plate.
    • This may require a little force as there are some plastic clips all around the front plate, use a plastic opening tool to detach then all around the perimeter of the front plate.
  6. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Preview of the front plate: passo 6, immagine 1 di 1
    • Here is the front plate completely detached so you can see where are all the clips that maintain it.
  7. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the back plate: passo 7, immagine 1 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the back plate: passo 7, immagine 2 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Remove the back plate: passo 7, immagine 3 di 3
    • Look at the bottom sides of the device indicated by the arrows numbered 1 and 2.
    • Left side (arrow number 1)
    • Right side (arrow number 2)
    • Look at the left side and pull at the end of the back plate in the direction indicated by the arrow (1) in order to detach the backplate.
    • Then repeat this step for the other side (2)
    • Once both ends are freed, you can simply pull on the backplate upwards to remove it.
  8. Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Replace the gasket of the water tank connector assembly: passo 8, immagine 1 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Replace the gasket of the water tank connector assembly: passo 8, immagine 2 di 3 Dolce Gusto Oblo gasket of the water tank connector assembly replacement, Replace the gasket of the water tank connector assembly: passo 8, immagine 3 di 3
    • Locate the water tank connector assembly on the back of the rest of the coffee machine.
    • Remove its gasket by lifting the gasket upwards using a spudger or a plastic opening tool or your hands.
    • The gasket is not glued and can be removed easily.
    • Then insert a new gasket in the water tank connector assembly using your hands.
    • This gasket is a lip seal, so make sure to put the new gasket in the right position as shown in the 3rd picture.
Conclusione
Altre 3 persone hanno completato questa guida.
Brendan
Membro da: 09/24/16
51.545 Reputazione
3 Guide realizzate
Un commento
Retour d'expérience :
Cette réparation a été assez simple, la partie la plus difficile a été de détacher la plaque avant, car elle est solidement maintenue par les attaches qui sont réparties tout autour de cette pièce et sa forme atypique complique son démontage. De même pour le remontage de cette pièce qui nécessite de faire plusieurs tentatives pour bien la rattacher.
La réparation tient bien dans le temps, il n'y a plus la moindre fuite, j'utilise l'appareil tous les jours. Un bref retour sur la durée dans le temps de cette réparation sera effectué dans environ 1 an après la rédaction de ce tutoriel. En raison du type de pièce remplacée, il est certain que cette réparation durera au moins aussi longtemps que quand l'appareil était neuf. Cet appareil obtient donc une seconde vie pour un simple joint remplacé.
Bilan de la réparation : 2,5 kg de déchet plastique et électronique évité.
Astuce : pour préserver l'environnement et avoir du bon café, il existe des dosettes réutilisables en métal pour cet appareil.
Brendan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 78
Ultimi 30 Giorni: 319
Tutti i Tempi: 5,676
