Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
NOTE: This guide is used for training purposes only. Do not use this guide for repair. For the official guide, follow this link.
Prerequisite-only guide for detaching the display assembly for access to the iPhone 11 internals.
  1. To access the screws in the following step, tilt the display by slightly lifting its lower edge. Be careful not to strain or tear the display cables.
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  2. Remove the bracket.
    • Remove the bracket.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  4. Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board. Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  5. Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket. Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket.
    • Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket.
  6. Remove the bracket.
  7. Use a spudger or a fingernail to disconnect the LCD panel cable connector. Disconnect the digitizer connector next to it. Disconnect the digitizer connector next to it.
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  8. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  9. Remove the display assembly.
Linea Traguardo
Arthur Shi
Membro da: 03/01/2018
139.766 Reputazione
389 Guide realizzate
iFixit Membro di iFixit
Community
131 Membri
13.475 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 113
