Salta al contenuto principale
Disassembling the Root Coding Robot
Cosa ti serve
  1. Disassembling the Root Coding Robot, Removing the bottom screws: passo 1, immagine 1 di 1
    • The first step in our disassembly is to remove the four bottom Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling the Root Coding Robot, Opening up the Root: passo 2, immagine 1 di 3 Disassembling the Root Coding Robot, Opening up the Root: passo 2, immagine 2 di 3 Disassembling the Root Coding Robot, Opening up the Root: passo 2, immagine 3 di 3
    • Once the screws are removed, simply flip the robot face up and lift the top cover. This will expose the Root's motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling the Root Coding Robot, Disconnecting some cables: passo 3, immagine 1 di 3 Disassembling the Root Coding Robot, Disconnecting some cables: passo 3, immagine 2 di 3 Disassembling the Root Coding Robot, Disconnecting some cables: passo 3, immagine 3 di 3
    • Remove the three screws holding the motherboard in place.
    • With a spudger, remove the four cables connected to the motherboard. This will allow us to lift it but there's still a couple of connectors to disconnect.
    • Don't force the motherboard out as the erasing mechanisms and color sensors are still connected to it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling the Root Coding Robot, Removing the motherboard: passo 4, immagine 1 di 2 Disassembling the Root Coding Robot, Removing the motherboard: passo 4, immagine 2 di 2
    • Now you can see both connectors still attached to the motherboard, remove them and simply set the motherboard aside.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling the Root Coding Robot, Side buttons: passo 5, immagine 1 di 2 Disassembling the Root Coding Robot, Side buttons: passo 5, immagine 2 di 2
    • With the motherboard out of the way, we can simply lift the side buttons and remove them.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling the Root Coding Robot, Motors: passo 6, immagine 1 di 3 Disassembling the Root Coding Robot, Motors: passo 6, immagine 2 di 3 Disassembling the Root Coding Robot, Motors: passo 6, immagine 3 di 3
    • Without the side buttons we can now easily access the three Phillips screws holding down the motors.
    • Unscrew them and remove the motors.
    Chiedi a FixBot
    Aggiungi Commento
  7. Disassembling the Root Coding Robot, Accessing the battery: passo 7, immagine 1 di 2 Disassembling the Root Coding Robot, Accessing the battery: passo 7, immagine 2 di 2
    • To access the battery, unscrew the 6 Phillips screws and remove the plastic piece.
    • With motors removed you can now see thge powerful magnets that hold this robot fixed on a whiteboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. Disassembling the Root Coding Robot, Battery: passo 8, immagine 1 di 2 Disassembling the Root Coding Robot, Battery: passo 8, immagine 2 di 2
    • With access to the battery, you can simply take it out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Disassembling the Root Coding Robot, Repositionning some cables: passo 9, immagine 1 di 2 Disassembling the Root Coding Robot, Repositionning some cables: passo 9, immagine 2 di 2
    • There's a little cable holder that makes sure the motor cables don't go everywhere, make sure to remove the cables from there.
    Chiedi a FixBot
    Aggiungi Commento
  10. Disassembling the Root Coding Robot, Erasing mechanism: passo 10, immagine 1 di 3 Disassembling the Root Coding Robot, Erasing mechanism: passo 10, immagine 2 di 3 Disassembling the Root Coding Robot, Erasing mechanism: passo 10, immagine 3 di 3
    • The cool thing about the Root robot is that it can go on a white board and it can erase stuff. That mechanism is shown here and it can be remove by unscrewing these four screws.
    • Once that's done, remove the erasing mechanism.
    Chiedi a FixBot
    Aggiungi Commento
  11. Disassembling the Root Coding Robot, Color sensor board: passo 11, immagine 1 di 3 Disassembling the Root Coding Robot, Color sensor board: passo 11, immagine 2 di 3 Disassembling the Root Coding Robot, Color sensor board: passo 11, immagine 3 di 3
    • To recognize colors, the Root uses a color sensor board at the bottom of the robot. Unscrew the five screws holding the board to the chassis.
    • Remove the board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations, you've made it to the end of the guide, and that concludes the Root Coding robot disassembly.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 22
Tutti i Tempi: 313
