Salta al contenuto principale
Disassembling the Nokia 6300
Cosa ti serve
  1. Disassembling the Nokia 6300, Rear Cover: passo 1, immagine 1 di 1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: passo 2, immagine 1 di 2 Disassembling the Nokia 6300: passo 2, immagine 2 di 2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: passo 3, immagine 1 di 1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: passo 4, immagine 1 di 1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: passo 5, immagine 1 di 1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: passo 6, immagine 1 di 3 Disassembling the Nokia 6300: passo 6, immagine 2 di 3 Disassembling the Nokia 6300: passo 6, immagine 3 di 3
    • There's your phone!
Conclusione
Altre 20 persone hanno completato questa guida.
LucasJV
Membro da: 05/18/10
741 Reputazione
3 Guide realizzate
1Commento della guida
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 43
Tutti i Tempi: 24,705
