Salta al contenuto principale
Disassembling the Linksys E1200
Cosa ti serve
  1. Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, immagine 1 di 3 Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, immagine 2 di 3 Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, immagine 3 di 3
    • Opening the device will void your warranty.
    • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
    • Remove the three screws.
    • Save the pads for reassembly.
  2. Disassembling the Linksys E1200: passo 2, immagine 1 di 3 Disassembling the Linksys E1200: passo 2, immagine 2 di 3 Disassembling the Linksys E1200: passo 2, immagine 3 di 3
    • Once the three screws are removed, the device is ready for disassembly.
    • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
    • Insert the plastic opening tool in the gap and begin prying on the corner.
    • Continue to pry around the body of the case. Separate both sides of the case with this method.
  3. Disassembling the Linksys E1200: passo 3, immagine 1 di 2 Disassembling the Linksys E1200: passo 3, immagine 2 di 2
    • Once the sides are released, the front of the cover can be removed.
    • Use a plastic opening tool to separate the front of the cover from the body.
    • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
  4. Disassembling the Linksys E1200: passo 4, immagine 1 di 3 Disassembling the Linksys E1200: passo 4, immagine 2 di 3 Disassembling the Linksys E1200: passo 4, immagine 3 di 3
    • The cover can now be removed.
    • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
    • Use caution when pulling on the tabs as they are stiff and easy to break.
    • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
  5. Disassembling the Linksys E1200: passo 5, immagine 1 di 3 Disassembling the Linksys E1200: passo 5, immagine 2 di 3 Disassembling the Linksys E1200: passo 5, immagine 3 di 3
    • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
    • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
    • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
Conclusione
Altre 13 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 7,075
