Introduzione
This guide provides steps on how to disassemble the Bezel to check if anything is blocking the casing, or to replace the Bezel if it happens to be broken.
Please follow the pre-requisite guide for the screen rotator first then follow the remaining steps to remove the Bezel.
Cosa ti serve
Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
Disconnect the wire from the system board using the plastic opening tool.
Disconnect the wire from the optical drive using the plastic opening tool.
Gently lift the top cover from the tablet.
