Salta al contenuto principale
Disassembling the Canon PowerShot A200 Case
Cosa ti serve
  1. Disassembling the Canon PowerShot A200 Case, Disassembling the Canon PowerShot A200 Case: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two screws at the bottom of the camera.
  2. Disassembling the Canon PowerShot A200 Case: passo 2, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 2, immagine 2 di 2
    • Locate a screw and a rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
    • Remove both screws with the Phillips #00 screwdriver.
  3. Disassembling the Canon PowerShot A200 Case: passo 3, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 3, immagine 2 di 2
    • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
    • Be sure to remove the memory card.
    • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
  4. Disassembling the Canon PowerShot A200 Case: passo 4, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 4, immagine 2 di 2
    • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
    • Remove the two visible screws with the Phillips #00 screwdriver.
    • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
  5. Disassembling the Canon PowerShot A200 Case: passo 5, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 5, immagine 2 di 2
    • Remove the screen battery located to the left of the screen.
  6. Disassembling the Canon PowerShot A200 Case: passo 6, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 6, immagine 2 di 2
    • Gently pull the camera apart from the top.
    • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
  7. Disassembling the Canon PowerShot A200 Case: passo 7, immagine 1 di 2 Disassembling the Canon PowerShot A200 Case: passo 7, immagine 2 di 2
    • Locate the black tabs on either side of the white ribbon.
    • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
    • Gently pull the white ribbon out from its connection.
  8. Disassembling the Canon PowerShot A200 Case: passo 8, immagine 1 di 3 Disassembling the Canon PowerShot A200 Case: passo 8, immagine 2 di 3 Disassembling the Canon PowerShot A200 Case: passo 8, immagine 3 di 3
    • Locate the black tabs on either side of the orange ribbon.
    • Gently pull the orange ribbon out of its connection.
    • Your camera will now be in two separate pieces.
Conclusione
Cal Poly, Team 7-37, Regan Winter 2011 Membro di Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 655
