Salta al contenuto principale
Disassembling of Wahl Lithium Ion Trimmer
Cosa ti serve
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: passo 1, immagine 1 di 2 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: passo 1, immagine 2 di 2
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: passo 2, immagine 1 di 1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: passo 3, immagine 1 di 2 Disassembling of Wahl Lithium Ion Trimmer: passo 3, immagine 2 di 2
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Conclusione
Altre 12 persone hanno completato questa guida.
3 Commenti
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Replica
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Replica
Thanks…worked well.
Magpie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 161
Tutti i Tempi: 43,912
