Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Push the back glass towards the top of the phone.
    • Push the back glass towards the top of the phone.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  5. Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top  connector sheild. Using a plastic opener tool, pry up the battery connector.
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  6. Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Chandler Skinner
Membro da: 15/10/2011
3.721 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 5,967
