Salta al contenuto principale
Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard
Cosa ti serve
  1. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard, Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 1, immagine 1 di 1
    • Insert wisdom here.
    Same with me. Better try to use a sharp knife around the edges of the black cover and carefully lift it, holding the knife flat. Do not bend too strongly or you will crack the thin glass/plastic cover.
    weberguy - Replica
  2. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 2, immagine 1 di 1
  3. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 3, immagine 1 di 1
  4. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 4, immagine 1 di 1
  5. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 5, immagine 1 di 1
  6. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 6, immagine 1 di 1
  7. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 7, immagine 1 di 1
  8. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 8, immagine 1 di 1
  9. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: passo 9, immagine 1 di 1
Conclusione
Altre 3 persone hanno completato questa guida.
Jonathan J
Membro da: 02/07/14
201 Reputazione
1 Guida realizzata
4 Commenti
I tried to open the black part but has cracked with the minimum attempt. Now I have broken the front glass with the black part.
melchorct - Replica
Historia, I cracked black glass (camera). where one can buy ? thanks
kamykazeandy -
same thing happened with me
but at least i was able to open it.
i have unplugged the battery fr long time but still not working, any suggestions???
nimer76 -
Same happened to me with the black camera cover. Do you guys found a replacement?
renehahn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 7,395
