Cosa ti serve
10 Commenti
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
how do you fix that i have busted screen on a bar 800 and need directions
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM -
I lost the the sound on this demo. Does anyone else have the same problem?
I was hoping that Andre could repost this repair. I only show a partial post. This fix is exactly what I need. Thanks, Sheila
Hello, useful repair description. It does not solve the whole but it helps .... My bar 800 was defect. Screen was flashing whole time, like a kind of reset during inilization that never ends up .... So all possible signs in display were shown and after 1 sec all off. This again and again...Thanks to the instructions i disassembled the station. I disoldered the small platine and seems to work ALL again!!! What is then the small platine for?! My suposition is that the small platine could be a barometer, that only is issued for wheater forecast. Now it is showing raining and maybe forever ....
Can you please repost or add once more your procedure?
