Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Oregon Scientific Ultra Thin Weather Station, usa il nostro manuale di assistenza.
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: passo 1, immagine 1 di 1
    • Weather Box, front side
  2. Disassembling Weather Box Oregon BAR800: passo 2, immagine 1 di 3 Disassembling Weather Box Oregon BAR800: passo 2, immagine 2 di 3 Disassembling Weather Box Oregon BAR800: passo 2, immagine 3 di 3
    • Rear side
  3. Disassembling Weather Box Oregon BAR800: passo 3, immagine 1 di 1
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
  4. Disassembling Weather Box Oregon BAR800: passo 4, immagine 1 di 3 Disassembling Weather Box Oregon BAR800: passo 4, immagine 2 di 3 Disassembling Weather Box Oregon BAR800: passo 4, immagine 3 di 3
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
  5. Disassembling Weather Box Oregon BAR800: passo 5, immagine 1 di 1
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  6. Disassembling Weather Box Oregon BAR800: passo 6, immagine 1 di 3 Disassembling Weather Box Oregon BAR800: passo 6, immagine 2 di 3 Disassembling Weather Box Oregon BAR800: passo 6, immagine 3 di 3
    • Internal view
Andres
Membro da: 11/14/13
110 Reputazione
1 Guida realizzata
10 Commenti
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Replica
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,240
