Questo smontaggio non è una guida di riparazione. Per riparare il tuo Oregon Scientific Ultra Thin Weather Station, usa il nostro manuale di assistenza.
  1. Weather Box, front side
    • Weather Box, front side
  2. Rear side Rear side Rear side
    • Rear side
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
  5. After plastic screen removed, it can see the screws. With a small screw driver, take them off. There are eight screws. With a small screw driver, take them off. There are eight screws.
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
  6. After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  7. Internal view Internal view Internal view
    • Internal view
Andres
Membro da: 14/11/2013
110 Reputazione
1 Guida realizzata
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Replica
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
I lost the the sound on this demo. Does anyone else have the same problem?
Sheila McWilliams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,073
