Salta al contenuto principale
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
Cosa ti serve
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: passo 1, immagine 1 di 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, immagine 2 di 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, immagine 1 di 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, immagine 2 di 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, immagine 1 di 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 5, immagine 1 di 1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 6, immagine 1 di 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 7, immagine 1 di 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 Guide realizzate
Un commento
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,010
