Salta al contenuto principale
Disassembling Trek 820 Tire Removal from Wheel
Cosa ti serve
  1. Disassembling Trek 820 Tire Removal from Wheel, Tire: passo 1, immagine 1 di 1
    • Locate the valve stem and remove the valve stem cap if one is present.
  2. Disassembling Trek 820 Tire Removal from Wheel: passo 2, immagine 1 di 1
    • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
    • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
  3. Disassembling Trek 820 Tire Removal from Wheel: passo 3, immagine 1 di 2 Disassembling Trek 820 Tire Removal from Wheel: passo 3, immagine 2 di 2
    • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
    • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
    • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
  4. Disassembling Trek 820 Tire Removal from Wheel: passo 4, immagine 1 di 3 Disassembling Trek 820 Tire Removal from Wheel: passo 4, immagine 2 di 3 Disassembling Trek 820 Tire Removal from Wheel: passo 4, immagine 3 di 3
    • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
    • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
  5. Disassembling Trek 820 Tire Removal from Wheel: passo 5, immagine 1 di 2 Disassembling Trek 820 Tire Removal from Wheel: passo 5, immagine 2 di 2
    • Remove the inner tube from the tire by simply pulling it from the tire carcass.
Conclusione
For tire reinstallation, simply follow these steps in reverse order.
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
9 Guide realizzate
1Commento della guida
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
John Sinclair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,336
