Salta al contenuto principale
Disassembling Toshiba T1960CS for HDD Removal
Cosa ti serve
  1. Disassembling Toshiba T1960CS for HDD Removal, HDD Removal: passo 1, immagine 1 di 1
    • Pry up cover, remove screw.
  2. Disassembling Toshiba T1960CS for HDD Removal: passo 2, immagine 1 di 1
    • Remove screws.
  3. Disassembling Toshiba T1960CS for HDD Removal: passo 3, immagine 1 di 1
    • Gently pry out to unsnap top plastic housing.
  4. Disassembling Toshiba T1960CS for HDD Removal: passo 4, immagine 1 di 1
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. Disassembling Toshiba T1960CS for HDD Removal: passo 5, immagine 1 di 1
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
Conclusione
Altre 4 persone hanno completato questa guida.
WayneG
Membro da: 05/13/13
191 Reputazione
1 Guida realizzata
Un commento
The plastic housing does not come off. It seems to be attached to the screen
James Blimthorpe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,061
