Salta al contenuto principale
Disassembling Toshiba A1304T Front Cover
Cosa ti serve
  1. Disassembling Toshiba A1304T Front Cover, Front Cover: passo 1, immagine 1 di 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Disassembling Toshiba A1304T Front Cover: passo 2, immagine 1 di 2 Disassembling Toshiba A1304T Front Cover: passo 2, immagine 2 di 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Disassembling Toshiba A1304T Front Cover: passo 3, immagine 1 di 2 Disassembling Toshiba A1304T Front Cover: passo 3, immagine 2 di 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Conclusione
Christopher
Membro da: 04/22/10
90 Reputazione
8 Guide realizzate
Cal Poly, Team 16-6, Maness Spring 2010 Membro di Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,132
