Salta al contenuto principale
Disassembling Speak And Spell Case
Cosa ti serve
  1. Disassembling Speak And Spell Case, Case: passo 1, immagine 1 di 2 Disassembling Speak And Spell Case, Case: passo 1, immagine 2 di 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: passo 2, immagine 1 di 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Conclusione
bushing
Membro da: 04/23/10
10.250 Reputazione
13 Guide realizzate
Un commento
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,983
