Salta al contenuto principale
Introduzione
This a simple process requiring only a small Phillips screwdriver and a slim flathead.
Note: A few trays for the screws, a wristband and an anti-static surface mat are ideal for safe handling of sensitive electronics.
  1. - Remove battery.
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. - Remove CD/DVD Drive by sliding it out.
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  5. - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  6. - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  7. - Fire up the air compressor and blow out dust from the fan and heatsinks.
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  8. - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Conclusione
Altre 6 persone hanno completato questa guida.
Artem Nikulkov
Membro da: 22/10/2010
259 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 20,494
