Salta al contenuto principale
Disassembling Sony Reader Touch Edition PRS-600 Inner Casing
Cosa ti serve
  1. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Back Panel: passo 1, immagine 1 di 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: passo 2, immagine 1 di 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: passo 3, immagine 1 di 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Battery: passo 4, immagine 1 di 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: passo 5, immagine 1 di 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing, Inner Casing: passo 6, immagine 1 di 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
  7. Disassembling Sony Reader Touch Edition PRS-600 Inner Casing: passo 7, immagine 1 di 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
Conclusione
Clemson, Team 1-4, Benson Fall 2014 Membro di Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 779
