Salta al contenuto principale
Disassembling Sony Ericsson W580i Back Cover
Cosa ti serve
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: passo 1, immagine 1 di 3 Disassembling Sony Ericsson W580i Back Cover, Battery: passo 1, immagine 2 di 3 Disassembling Sony Ericsson W580i Back Cover, Battery: passo 1, immagine 3 di 3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: passo 2, immagine 1 di 1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: passo 3, immagine 1 di 1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: passo 4, immagine 1 di 3 Disassembling Sony Ericsson W580i Back Cover: passo 4, immagine 2 di 3 Disassembling Sony Ericsson W580i Back Cover: passo 4, immagine 3 di 3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
Conclusione
Altre 4 persone hanno completato questa guida.
Cherie
Membro da: 10/09/11
220 Reputazione
2 Guide realizzate
Cal Poly, Team 5-31, Amido Fall 2011 Membro di Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 8,397
