Salta al contenuto principale
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
Cosa ti serve
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: passo 1, immagine 1 di 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: passo 1, immagine 2 di 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 2, immagine 1 di 1
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 1 di 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 2 di 3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 3 di 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 4, immagine 1 di 2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 4, immagine 2 di 2
    • Use hands to gently pry the front casing away from the camera.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,563
