Salta al contenuto principale
Disassembling Sony Cyber-Shot DSC-W330 Outer Casing
Cosa ti serve
  1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: passo 1, immagine 1 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: passo 1, immagine 2 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: passo 1, immagine 3 di 3
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
  2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 2, immagine 1 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 2, immagine 2 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 2, immagine 3 di 3
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
  3. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 3, immagine 1 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 3, immagine 2 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 3, immagine 3 di 3
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
  4. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 4, immagine 1 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 4, immagine 2 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 4, immagine 3 di 3
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  5. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 5, immagine 1 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 5, immagine 2 di 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: passo 5, immagine 3 di 3
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 13-4, Benson Fall 2013 Membro di Clemson, Team 13-4, Benson Fall 2013
CLEM-BENSON-F13S13G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 806
