Salta al contenuto principale
Disassembling Sony Clie PEG-NR70 The Case
Cosa ti serve
  1. Disassembling Sony Clie PEG-NR70 The Case, The Case: passo 1, immagine 1 di 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Disassembling Sony Clie PEG-NR70 The Case: passo 2, immagine 1 di 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Disassembling Sony Clie PEG-NR70 The Case: passo 3, immagine 1 di 2 Disassembling Sony Clie PEG-NR70 The Case: passo 3, immagine 2 di 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
Conclusione
Daniel Soski
Membro da: 04/18/13
57 Reputazione
6 Guide realizzate
Cal Poly, Team 14-11, Maness Spring 2013 Membro di Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 664
