Salta al contenuto principale
Introduzione
The lithium-ion battery is needed in order to provide power to the Snapfon ez One.
Parti
Nessuna parte specificata.
  1. Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Remove the back battery cover by sliding it downward and pushing simultaneously.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Skip the upgrade.
    Ottieni $10 di sconto su $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  3. Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
Conclusione
You can now insert the new battery in the same manner as when you disassembled it. Now, to reassemble your device, follow these instructions in reverse order.
John Bender
Membro da: 26/03/2014
822 Reputazione
8 Guide realizzate
Clemson, Team 6-5, Benson Spring 2014 Membro di Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 416
