Salta al contenuto principale
Disassembling Sirius Stiletto 100 Internal Antenna
Cosa ti serve
  1. Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: passo 1, immagine 1 di 2 Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: passo 1, immagine 2 di 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Internal Antenna: passo 2, immagine 1 di 2 Disassembling Sirius Stiletto 100 Internal Antenna: passo 2, immagine 2 di 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Internal Antenna: passo 3, immagine 1 di 3 Disassembling Sirius Stiletto 100 Internal Antenna: passo 3, immagine 2 di 3 Disassembling Sirius Stiletto 100 Internal Antenna: passo 3, immagine 3 di 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Internal Antenna, Circuit Board: passo 4, immagine 1 di 1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Internal Antenna: passo 5, immagine 1 di 2 Disassembling Sirius Stiletto 100 Internal Antenna: passo 5, immagine 2 di 2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Internal Antenna: passo 6, immagine 1 di 1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  7. Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: passo 7, immagine 1 di 3 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: passo 7, immagine 2 di 3 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: passo 7, immagine 3 di 3
    • Flip the circuit board over to look at the back side, so that LCD screen is facing away from you.
    • Use a Phillip's head screwdriver to remove the screw from the back of the internal antenna.
  8. Disassembling Sirius Stiletto 100 Internal Antenna: passo 8, immagine 1 di 2 Disassembling Sirius Stiletto 100 Internal Antenna: passo 8, immagine 2 di 2
    • Use your fingers to pry the internal antenna off of the circuit board. You may need to wiggle it back and forth to successfully remove it.
    • Woohoo! You have removed the internal antenna!
Conclusione
Trey
Membro da: 03/09/12
80 Reputazione
2 Guide realizzate
Clemson, Team 2-1, Benson Spring 2012 Membro di Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,848
