Salta al contenuto principale
Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing
Cosa ti serve
  1. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing, Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 1, immagine 1 di 1
    • Camera lens are delicate and intricate. Be careful with the disassembly and work slowly.
    • Take the lens away from camera
    • DO NOT FORGET: THAT YOU ARE DOING ALL ON YOUR OWN RESPONSIBILITY
  2. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 2, immagine 1 di 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 2, immagine 2 di 2
    • Unscrew the top part and detach it.
    • Unjoin cables. Be careful; they're delicate, and easily torn.
    • Try to avoid touching sensitive electronic components.
    • Unfasten the screws that hold the circuit board in place, and separate it from the rest of the lens assembly.
  3. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 3, immagine 1 di 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 3, immagine 2 di 2
    • Take away zoom rubber and you will find srews
  4. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 4, immagine 1 di 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 4, immagine 2 di 2
    • Keep unscrewing and removing the parts until you reach what you need to fix.
    • Zoom bearing can be taken away by unscrewing its srews.
  5. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: passo 5, immagine 1 di 1
    • Here is one of the parts which was broken, so I go to camera repair shop, and bought that parts. As this was not the only part broken, I had to leave for additional repair.
    • When you finish you can put all back together
Conclusione
Altre 6 persone hanno completato questa guida.
Rimvydas
Membro da: 03/29/12
718 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 67
Tutti i Tempi: 30,347
