Salta al contenuto principale
Disassembling Siemens A56 Motherboard Metal Frame
Cosa ti serve
  1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: passo 1, immagine 1 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: passo 1, immagine 2 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: passo 1, immagine 3 di 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: passo 2, immagine 1 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: passo 2, immagine 2 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: passo 2, immagine 3 di 3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  3. Disassembling Siemens A56 Motherboard Metal Frame: passo 3, immagine 1 di 3 Disassembling Siemens A56 Motherboard Metal Frame: passo 3, immagine 2 di 3 Disassembling Siemens A56 Motherboard Metal Frame: passo 3, immagine 3 di 3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  4. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: passo 4, immagine 1 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: passo 4, immagine 2 di 3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: passo 4, immagine 3 di 3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
Conclusione
Joseph Casey
Membro da: 03/26/14
409 Reputazione
4 Guide realizzate
Clemson, Team 6-6, Benson Spring 2014 Membro di Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 158
