Salta al contenuto principale
Disassembling Sanyo VPC-T850 Outer Casing
Cosa ti serve
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: passo 1, immagine 1 di 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: passo 2, immagine 1 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: passo 2, immagine 2 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: passo 2, immagine 3 di 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: passo 3, immagine 1 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: passo 3, immagine 2 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: passo 3, immagine 3 di 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: passo 5, immagine 1 di 1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: passo 6, immagine 1 di 2 Disassembling Sanyo VPC-T850 Outer Casing: passo 6, immagine 2 di 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: passo 7, immagine 1 di 2 Disassembling Sanyo VPC-T850 Outer Casing: passo 7, immagine 2 di 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: passo 8, immagine 1 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: passo 8, immagine 2 di 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: passo 8, immagine 3 di 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Conclusione
Cal Poly, Team 27-95, Amido Spring 2010 Membro di Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,038
