Salta al contenuto principale
Disassembling Sanyo Katana Eclipse X's Back Panel
Cosa ti serve
  1. Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: passo 1, immagine 1 di 2 Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: passo 1, immagine 2 di 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X's Back Panel: passo 2, immagine 1 di 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
Conclusione
Thomas Scaggs
Membro da: 10/15/12
215 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 405
