Salta al contenuto principale
Disassembling SanDisk Sansa Fuze
Cosa ti serve
  1. Disassembling SanDisk Sansa Fuze, Sansa Fuze MP3 Player: passo 1, immagine 1 di 1
    • Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
    The clips are square loops protruding front the front clear polycarbonate, and are quite brittle, they are prone to breaking
    Giles Phillips - Replica
  2. Disassembling SanDisk Sansa Fuze: passo 2, immagine 1 di 1
    • Remove ribbon cable connect to the face plate. Lift the face off and flip the brown ribbon release flap on the connection on the board. (The flap in this picture is black, opposite the cable. Lift the edge that is closest to you in the picture in order to release the cable.)
    I still cant remove the ribbon part am i supposed to lift the black part up or the white one
    lord isaias - Replica
  3. Disassembling SanDisk Sansa Fuze: passo 3, immagine 1 di 1
    • Remove two (in some versions there are 3) screws holding the board down
  4. Disassembling SanDisk Sansa Fuze: passo 4, immagine 1 di 2 Disassembling SanDisk Sansa Fuze: passo 4, immagine 2 di 2
    • Remove LCD by releasing the 4 clips on each side of the LCD, be carefully to not damage the LCD
  5. Disassembling SanDisk Sansa Fuze: passo 5, immagine 1 di 1
    • Carefully flip the LCD over and disconnect the LCD cable from the board
  6. Disassembling SanDisk Sansa Fuze: passo 6, immagine 1 di 1
    • Remove battery. The battery is taped down with a little double sided tape
    • If you are replacing the battery just apply a soldering iron to the battery connections on the board and gently pull them off..
    • To re-attached the new battery by reheating the old solder and reconnecting the new battery wires
    • Link to a battery Battery Clerk - Sansa Fuze battery
    • PLEASE NOT IF REPLACING THE BATTERY YOU DO NOT NEED TO REMOVE THE BOARD :)
    Replacement batteries may come with a large sticker with branding and warnings on that may make them too bulky to fit, peel this off and it should fit.
  7. Disassembling SanDisk Sansa Fuze: passo 7, immagine 1 di 1
    • Remove the board by lifting on the left side first as to work around the on off switch.
Conclusione
Altre 8 persone hanno completato questa guida.
James
Membro da: 03/17/13
493 Reputazione
1 Guida realizzata
Everything iPod Membro di Everything iPod
Community
62 Membri
3 Guide realizzate
6 Commenti
Hi,
I've lost the brown ribbon release flap. So my ribbon cable has no connection most of the time. Is there any chance to replace this with something else? Or get a new connector?
Thanks,
Simon
moony - Replica
Sep 7 is backwards - device power button is on the right side, release motherboard on that side first. Otherwise thank you for the guide!
Killen Prophet - Replica
Hi; I can't reconnect the ribbon cable in step 2, please help anyone. I tried regular tweezers, they are too big and the cable is too short.
Pat - Replica
Thanks so much for this post! It was a big help in getting my screen fixed and everything re-connected! Love my sansa fuze!
Penney H - Replica
Fixed my First Sandisk Fuse! I have had probably 10 over the last 15 years and finally got to repair one! Great Advice!
J.J. - Replica
Just completed this guide to replace a tired battery, added some notes. The case doesn't clip back together too well due to the broken clips, but I have a leather case it fits in, which holds it together adequately.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 82
Tutti i Tempi: 19,020
