Salta al contenuto principale
  1. Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
    • Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
  2. Remove ribbon cable connect to the face plate. Lift the face off and flip the brown ribbon release flap on the connection on the board.  (The flap in this picture is black, opposite the cable.  Lift the edge that is closest to you in the picture in order to release the cable.)
    • Remove ribbon cable connect to the face plate. Lift the face off and flip the brown ribbon release flap on the connection on the board. (The flap in this picture is black, opposite the cable. Lift the edge that is closest to you in the picture in order to release the cable.)
  3. Remove two (in some versions there are 3) screws holding the board down
    • Remove two (in some versions there are 3) screws holding the board down
  4. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  5. Remove LCD by releasing the 4 clips on each side of the LCD, be carefully to not damage the LCD Remove LCD by releasing the 4 clips on each side of the LCD, be carefully to not damage the LCD
    • Remove LCD by releasing the 4 clips on each side of the LCD, be carefully to not damage the LCD
  6. Carefully flip the LCD over and disconnect the LCD cable from the board
    • Carefully flip the LCD over and disconnect the LCD cable from the board
  7. Remove battery. The battery is taped down with a little double sided tape
    • Remove battery. The battery is taped down with a little double sided tape
    • If you are replacing the battery just apply a soldering iron to the battery connections on the board and gently pull them off..
    • To re-attached the new battery by reheating the old solder and reconnecting the new battery wires
    • Link to a battery Battery Clerk - Sansa Fuze battery
    • PLEASE NOT IF REPLACING THE BATTERY YOU DO NOT NEED TO REMOVE THE BOARD :)
  8. Remove the board by lifting on the left side first as to work around the on off switch.
    • Remove the board by lifting on the left side first as to work around the on off switch.
Conclusione
Altre 5 persone hanno completato questa guida.
James
Membro da: 17/03/2013
393 Reputazione
1 Guida realizzata
Everything iPod Membro di Everything iPod
Community
61 Membri
5 Guide realizzate
Hi,
I've lost the brown ribbon release flap. So my ribbon cable has no connection most of the time. Is there any chance to replace this with something else? Or get a new connector?
Thanks,
Simon
moony - Replica
Sep 7 is backwards - device power button is on the right side, release motherboard on that side first. Otherwise thank you for the guide!
Killen Prophet - Replica
Hi; I can't reconnect the ribbon cable in step 2, please help anyone. I tried regular tweezers, they are too big and the cable is too short.
Pat - Replica
Thanks so much for this post! It was a big help in getting my screen fixed and everything re-connected! Love my sansa fuze!
Penney H - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 77
Tutti i Tempi: 13,276
