Salta al contenuto principale
Disassembling the Samsung Laptop Ultrabook NP530U3B
Cosa ti serve
  1. Disassembling the Samsung Laptop Ultrabook NP530U3B, Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 1, immagine 1 di 1
    • Remove the 8 small screws.
  2. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 2, immagine 1 di 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 2, immagine 2 di 2
    • Remove the other 6 screws.
    • Remove the hard disk and the RAM slots.
  3. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 3, immagine 1 di 1
    • This is the hard disk - Hitachi 500 GB
  4. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 4, immagine 1 di 1
    • Ensure that the hard disk has been removed. Carefully detach the bottom cover.
  5. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 5, immagine 1 di 1
    • Once the bottom cover is removed, your device should look like this.
  6. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 6, immagine 1 di 1
    • Remove the 4 screws to detach the battery.
    • Remove all of the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
    • The connector won't come out all the way, because the battery pack is in its way.
  7. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 7, immagine 1 di 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 7, immagine 2 di 2
    • This is the Samsung 7.4V 45Wh battery.
    • Ensure that the battery is removed before continuing.
  8. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 8, immagine 1 di 1
    • When the battery is removed, this is how it will look.
  9. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 9, immagine 1 di 1
    • Remove the processor fan.
    • There are 2 screws holding it in place. Loosen and remove them.
  10. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 10, immagine 1 di 1
    • This is the processor fan.
  11. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 11, immagine 1 di 1
    • Remove the processor heat sink.
    • 3 screws hold this part in place. Loosen and remove them.
  12. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 12, immagine 1 di 1
    • Disconnect the antenna cables from the WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  13. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 13, immagine 1 di 1
    • Remove the screw.
    • Lift the latch upwards to loosen the cable.
  14. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 14, immagine 1 di 1
    • Remove the screw.
  15. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 15, immagine 1 di 1
    • Remove the screw.
  16. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 16, immagine 1 di 1
    • To remove the Motherboard, carefully disconnect the cables.
  17. Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 17, immagine 1 di 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: passo 17, immagine 2 di 2
    • This is the Motherboard - there is a front and rear view.
Conclusione
Altre 34 persone hanno completato questa guida.
30 Commenti
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Replica
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Replica
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Replica
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 75
Tutti i Tempi: 52,903
