Salta al contenuto principale
Disassembling Samsung Gravity SGH-T459 Rear Case
Cosa ti serve
  1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Back Cover: passo 1, immagine 1 di 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Battery: passo 2, immagine 1 di 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: passo 3, immagine 1 di 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: passo 3, immagine 2 di 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: passo 3, immagine 3 di 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 387
