Introduzione
This guide will walk you through how to disassemble the Samsung Gear 2.
Parti
Nessuna parte richiesta.
Before disassembling your Gear, be sure it is powered off.
  • Before disassembling your Gear, be sure it is powered off.
  • To remove each strap, locate the metal latches on both sides of the back of the Gear.
  • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Aggiungi Commento
Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
Aggiungi Commento
  • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
  • Pry the device open from the other side also if it does not fully disassemble from one side.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Jonathan Molina
Membro da: 14/04/2014
886 Reputazione
2 Guide realizzate
Cal Poly, Team 13-27, Maness Spring 2014 Membro di Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,802
