Salta al contenuto principale
Introduzione
This guide tells you how to remove the back or rear panel of the Samsung Epic 4G, which is an important first step in working with the internal parts of the phone.
  1. Turn off the phone using the "Power Button" located on the left side of the phone.
    • Turn off the phone using the "Power Button" located on the left side of the phone.
    • Slide your fingernail along the edge of the device and pull at the plastic backing as shown in the figure.
    • While pulling at the backing, you will hear a snap. This means it is coming off the phone.
  2. After hearing the snap, pull at the plastic backing gently to remove it.
    • After hearing the snap, pull at the plastic backing gently to remove it.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 24-25, Regan Fall 2012 Membro di Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 773
