Salta al contenuto principale
Disassembling SKIL 4235 Jigsaw Base plate
Cosa ti serve
  1. Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: passo 1, immagine 1 di 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: passo 1, immagine 2 di 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: passo 1, immagine 3 di 3
    • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  2. Disassembling SKIL 4235 Jigsaw Base plate: passo 2, immagine 1 di 1
    • Using two hands grip both side of the saw and lay on side.
  3. Disassembling SKIL 4235 Jigsaw Base plate: passo 3, immagine 1 di 1
    • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
  4. Disassembling SKIL 4235 Jigsaw Base plate: passo 4, immagine 1 di 1
    • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
Conclusione
Adam Cardoso
Membro da: 11/12/13
357 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,040
