Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Disconnect the power supply cord from the outlet.
    • Disconnect the power supply cord from the outlet.
  2. Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  5. Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
Conclusione
Altre 3 persone hanno completato questa guida.
Samuel
Membro da: 26/09/2012
142 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,665
